Onan microlite 4000
myface
I have Onan Microlite 4000 4KY FA261100J. Does any one have wiring diagram for that genset. I have 3 different but none shows wiring for mine. What is most confusing, all shows 15 pin connector and mine have way more pins going to computer. I am having problem with fuel shut off solenoid - not getting voltage. Previous owner replaced carburetor and mess up the wiring going to fuel shut off solenoid. I am trying to locate the pin so I can bypass the wire and run new one. The gen will run if I jump 12v to that solenoid.
30 REPLIES 30
enblethen
Jumping is quickest way, however you could have vacuum leak if on engine side of carb.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
myface
The previous owner replaced the carburetor and apparently got the wire pinch. My options: jump the wire, take of the carburetor or take the gen down on ground to get access to this wire. I vote for jump.
enblethen
Sounds like on right track!
I would hate to see you bypass the wire and have it be a pin in the connector.
With your posts on other items, the previous owner(s) must have really butchered the wiring.
Bud
USAF Retired
Pace Arrow
myface
I did try but I am getting mix results. Suspecting damage wire
enblethen
It is possible that the pin is pushed back into the connector.
Yes, pin 3
You should be able to back probe the wire in the connector to check for output or have you tried to do so.
Bud
USAF Retired
Pace Arrow
myface
There is better photo of computer connections http://jestarkel.com/pics/3.jpg
Unlike the other connectors this one have 3 rows of pins. Looking horizontal from 1-8 the 3rd one should be the fuel shut off solenoid. Previous testing that one shows occasional continuity, but was not conclusive. I an suspecting the wire is damage that is why I am trying to bypass.
enblethen
Those photos opened.
In photo one, I can see pin numbers on the right side.
Pin 2 on the J connector should go to the fuel solenoid.
Bud
USAF Retired
Pace Arrow
myface
http://jestarkel.com/pics/1.jpg
http://jestarkel.com/pics/2.jpg
works for me.
MountainAir05
https://www.partsfortechs.com/asapcart/index.php?main_page=product_info&products_id=1384
Another source maybe and only if needed. Needs some more troubleshooting .
enblethen
Is this what it looks like?
Circuit board
Bud
USAF Retired
Pace Arrow
enblethen
Search sys that is a panel membrane.
Your previous post of photo did not work for me.
Bud
USAF Retired
Pace Arrow
myface
Numbers from sticker 300-5446 ES-0243560G13
enblethen
Can you get the computer number off yours? Do not try to use from drawings.
Looking at a couple drawings, some of the pins are not used and on drawing that shows remote (fig 12-21) start indicates less wires and then jumpered at remote start/stop.
Bud
USAF Retired
Pace Arrow
enblethen
Spec letter is commonly in a separate block from model number.
Will look to see what I come up with.
Bud
USAF Retired
Pace Arrow
