Aug-10-2021 12:48 PM
Aug-26-2021 01:06 PM
memtb wrote:pnichols wrote:
I do not let our Class C motorhome's V10 rev past around 4000 RPM on grades. I just stay in the right hand lane, or on two lanes roads pull off periodically so others can pass.
This works best on the multiple-lane highways/freeways/Interstates that have a lot of big rig traffic. With my V10 revving no higher than around 4000 RPM, max, on grades, I usually find our motorhome moseying comfortably up grades right along with the big rigs. This makes for low stress, lower V10 noise, lower engine wear, and best-as-possible V10 gas mileage on grades.
You’re more patient than I! ?? I’m accustomed to towing our 5th wheel (20K) with our diesel pickup, and passing the semi’s and most often maintaining the speed limit, or my chosen 65 mph.
I even considered the diesel conversion for ours, but couldn’t justify, as we’re not using the “c” nearly enough! memtb
Aug-26-2021 07:21 AM
Aug-25-2021 11:20 AM
Aug-22-2021 08:11 AM
Aug-21-2021 10:33 AM
NamMedevac 70 wrote:
I love gas with a 32 gallon tank in my truck. It is also so useful such as my portable camping generator, etc.
Aug-21-2021 07:24 AM
Aug-20-2021 05:50 PM
wintersun wrote:
My first choice for a Class B is the gas engine and for a Class C built on a 4500 Class chassis. The Mercedes diesel engine is very reliable but it is only available with the Sprinter 3500 chassis so the OCCC is less than half that of a E-450 chassis. Huge difference betwween a GVWR of 11,030 lbs as with the Mercedes Sprinter 3500 and a GVWR of 12,500 and 14.500 with the Ford E-450 chassis.
With our 2021 Navion 24D the OCCc is only 886 lbs which includes the weight of my wife and I and our e-bikes on a rack attached to the hitch receiver, clothing, cookware, food, and gear, leaving an allowance of less than 140 lbs for fresh water, grey water, and and black waste. With only 15 gallons of fresh water and empty gray and black holding tank, we are at 100% of the OCCC of the motorhome.
Where the diesel engine can help is with added range from getting more miles per gallon but the Sprinter chassis have a small gas tank as this platform is designed for use as a commercial van and not for motorhomes.
Aug-20-2021 01:21 PM
Aug-13-2021 08:58 AM
bobndot wrote:
I think Amazon has come to the realization regarding the Sprinters. They are replacing them with the Dodge PM and Ford Transit.
Aug-13-2021 07:51 AM
Aug-12-2021 05:26 PM
BillyandKris wrote:
...BTW I AM the wife!! LOL
Aug-12-2021 04:27 PM
Aug-12-2021 09:54 AM
Aug-12-2021 01:03 AM
