shaneperch
May 12, 2013Explorer
P30 Chassis
I would like to know. can you get high geared rear ends for the P30 chassis? someday I would like to get a higher geared ring and pinion to get the rpms down a little. anyone ever done that?
shaneperch wrote:And that is the exact question I have, based on my experience with TC slip.sjholt wrote:
You might look around for a used Gear Vendor overdrive unit. It worked nicely in the P30 I had..New ones run $2700.
They bolt up to the turbo 400 trans, then all you have to do is shorten the drive shaft- about $120.
How much mileage gain did you see using that overdrive?
