Daveinet wrote:
those were shorter chassis. .
Triple E A3201 (33 feet), Fully loaded for a month, 5 passengers, water tanks full, gas tank full. Scaled weight front axle 2450kg (5400lb) back 5001kg (11020LB), total 16419 or 81 lb shy of being overweight :)
The big ticket on my rig was replacing all the front steering parts with supersteer (specially bellcranks). It also has a anti-sway system in the front and air bags in the back. Drives so nice
Agreed with max length and check for slide outs too (they add weight).
But then again if I had a choice I would have gone with a Ford, not because it's better because parts availibility is so much better and a solid front axle is simple.
