rgatijnet1 wrote:
One is to completely FLUSH the brake fluid every two years. This is not bleeding the brake system. This means running almost three quarts of brake fluid through your system to completely change the fluid.
The second thing that needs to be done is that the caliper brake disc slides need to be lubricated so that the calipers slide freely. If this is done every two years, your brakes will be fine for years to come.
Think of it as cheap insurance for your own safety and piece of mind.
I like your wording better than mine-- "complete bleed" is not as descriptive as FLUSH. We do the same thing, but yours is the better description.
And for any brake system with SLIDING CALIPERS (as opposed to fixed calipers) the clean and lube caliper slides is very important.
This is NOT just on gasoline rigs!
Our 1998 Safari Sahara DP had sliding caliper hydraulic brakes, requiring disassembly and greasing with caliper slide grease.
Our 2003 Alpine had fixed caliper hydraulic brakes, so this procedure not needed (or even possible).
And, yes, sliding caliper air disk brakes (like on Foretravel) require the same inspection, cleaning and lubing of caliper slide pins.
Now, for the best way to FLUSH hydraulic brakes:
Suck all fluid from the brake master cylinder or reservoir.
Fill with new fluid. Stir with clean screwdriver, etc.
Suck out fluid. Repeat until fluid is CLEAR. You do NOT want to run dirty/hydrated brake fluid through the system.
Go to the right rear wheel (furthest from master cylinder). Suck out fluid while someone is adding new fluid to master cylinder/reservoir until clear, clean fluid comes out.
Do the same at the left rear, then right front, then left front.
Verify that fluid level in the master cylinder/reservoir is correct.
REPEAT EVERY 2-3 YEARS.
