C350amg's avatar
C350amg
Parts numbers and website
After my long trip across Canada and the US I am back home in Canada and I have to get my motorhome fixed.
It's a 32 feet Triple E 1998 on a 16,500LB P30 chassis with a 7.4 Vortec.
I have to change the front coil springs and the air bags, I also have to change the AC evaporateur (it's leaking) and some type of switch in front of it which is also leaking (it's either the low pressure switch or the fan switch).
Anybody knows the part numbetrs and a good website to order it from which delivers to Canada.
Thanks in advance
  • I Would like to keep the original spring set up.
    I already have the bell cranks and all the other steering parts from Henderson installed 2 months ago
  • Gjac's avatar
    Gjac
    What Bud said for the super springs. The leaking switch is called the trinary switch if you call Evans the maker of the AC unit they can direct you where to get it in Canada.
  • I would suggest replacing the springs with these from Henderson Line up which uses no coils springs as in most P-30 chassis. They run about $350 US and takes about 3 hours to install including alignment.
    Super steer springs
  • Your Triple E was built in Winkler Manitoba., Canada!
    Contact the manufacturer.
