JCat's avatar
JCat
Dec 13, 2014
Pioneer GPS/Radio Replacement
My Pioneer AVIC d2 seems to have died. It has power but screen does not power up.
So I need to fix or replace.
Anyone sent one in for repairs ? How did it go ?
If I replace, anyone gotten a combo with a GPS/Radio/Backup camera all in 1 ?
Let me know.
  • JCat's avatar
    JCat
    I finally completed the solution. I purchased a Pioneer 5700 radio/cd/dvd/sat radio/with ipod connection and had it installed. It also has an input for a backup camera, which I did not need as I already have a backup camera.
    I have a 9 inch tablet that I have loaded Delorme SW on and will use this for my GPS.
    Cost me $550 for the work, life is good.
    JCat
  • Having had my Pioneer repaired, it is worth it. The factory repaired mine for less than $300. A comparable replacement is over $600 and will require reinstallation and wiring. Not just plugging back in.
  • JCat's avatar
    JCat
    thanks for the tip on the reset, it did not power up.
    I will look at getting a new GGS
  • 1. Have you tried hitting the reset button on the front display? That is the very small indent you use a ball point pin to push and hold for 10 seconds.
    2. Your system is 10 years old, and not worth repairing. You can get a replacement for a lot less than repair and it will have all the current modern features that are standard today. The only problem may be the flip up design. Doug
  • They will charge at least $75 to tell you it doesn,t work. New ones are not that expensive.
  • wa8yxm's avatar
    wa8yxm
    In days of old when folks were bold and I was studying Electronics, PIONEER was one of the big boys.
    www.crutchfield.com has about the best catalog of replacements of anyone.
