Sort By
- NomadacExplorerAll of my TT's and MH have had the bathroom sink, shower and kitchen sink plumbed to the Gray tank. That is what I would always prefer.
- The majority of them go to the Gray tank. But, if you have a certain floorplan design, that makes running a sink to the gray water impossible, they will plumb to the black. There is NO code that states ONLY Black(toilet) water can go to a Black tank. Doug
- Dick_BExplorerIs it only the sink that is piped to the Black Tank? What about the shower?
- wa8yxmExplorer IIIWash tank (if you have one) is the same as Gray only no kitchen sink.
If not wash tank (or if it is remote) then gray tank is next choice
Finally some Makers hook it to the black tank, That is NOT something mine did or I would recommend. but that's how some do it.
Reasons:
In many areas WASH tank can be dumped on ground, at least when fresh (not held)
In some (Fewer) areas, so can GRAY
Black must ALWAYS go into a proper hole in the ground (Sewer system or pump out truck/wagon that goes to a hole in the ground)
NOTE: some areas require all 3 go into a proper sanitary sewer, But Well.. The farther you are from black, the more likely to be legal dumping on ground. - wildtoadExplorer II
Ronnietris wrote:
I have a 2015 thor hurricane and my son left the sink on a crack and we only had a grey water hook up site and it caused the black water tank to overflow through the toilet does that make sense?
Yep! - wildtoadExplorer IIOur unit plumbs the bathroom sink to the black tank. I'd rather it go to the gray. If yours is similar, the shower will go to the gray along with the kitchen sink.
- RonnietrisExplorerI have a 2015 thor hurricane and my son left the sink on a crack and we only had a grey water hook up site and it caused the black water tank to overflow through the toilet does that make sense?
- Trumpet_PlayerExplorerGrey. Never have seen one go to the black tank.
- anconnExplorerGrey
- nomad297ExplorerIt can go to either.
Bruce
About Motorhome Group
38,716 PostsLatest Activity: Apr 27, 2025
