gretchenjack, I answered your pm, however....I ran out of characters. This is the balance of my written novel! ?? I was not allowed to send a second pm!
Just this morning I discovered, that I need to replace the rear springs on mine. They had lost their set ( went flat) over the years with the weight (Bigfoot’s are very heavy) setting on them. Ford offered 2 different spring packs on the E 450. Mine had the lighter 5100 pound springs, should have had the 7200 pound springs. These will be $300.00/ per side, just for the springs.....I’ll do the work. Rv’ing can/will be very expensive!
I’m not trying to scare you, just want you to be aware of potential additional expenditures! You really should have several thousand “disposable” dollars...after your purchase. There will be many little things on a unit of this age than can crop-up. On the Ford part alone, serpentine belt, heater and radiator hoses, transmission flush ( I recommend, because of age and lack of use). Hopefully you can perform many of the small, non technical tasks yourself....it can save you many hundreds of dollars. Shop time is “very” expensive, whether it’s major repairs or very minor.....the hourly rate is the same!
I hope that all of this did not overwhelm you or depress you.....just want you to be aware!
Best Wishes and Hope All Works Out for You,
Todd
