Happytracks
Jul 13, 2013Explorer
dons2346 and dougrainer:
The touch panel doesn't show the travel light (blue). It shows two red lights for the two front air bags.
I have the Repair Manual for H.W.H. Leveling System, 500 Series.
In going through the repair steps, the manual eliminates everything I have gone through up to step #7, which states, "Replace the two travel solenoids. If this doesn't cure the problem, check height control valve".
It's a 1998 Country Coach Allure. I have had no mechanical problems since I bought it in March. It was garaged the last 10 years. Just needed some updating, flat screen tv, new color back-up camera, eterna bond on roof outlets, etc., which I have done myself and saved about $3,000. That's a lot of diesel.
I have found the manifold for the solenoids. Now have to find a place to park the motorhome so I can get under it.
Dougrainer, sounds like your response came right out of the repair manual.
Thanks to you both.
Happytracks
Thanks to you both.
Happytracks
