gb76087's avatar
gb76087
Programmable Thermostat on Intellitec ECC
I've got a Fleetwood Terra, 30 amp, with the Intellitec ECC thermostat and EMS. It sure would be nice to have a programmable thermistor(i.e. digital thermostat) to replace the thermistors that are provided. Thinking you could leave the ECC thermostat on to cool or heat and let the programmable thermostat provide the signal on when to come on or go off. Sounds simple enough, which means it probably can't be done. Someone please explain what I'm missing.
  • gb76087 wrote:
    Doug,
    Anyway to replace the temp thermistors with programmable thermostat? Serve same purpose, just not sure if possible.
    No. The Thermisters just send a OHM signal to the AC control boards. Doug
  • Doug,
  • There is no way to connect the Temp Thermisters to your aftermarket wall tstat. Doug
