Propane and tunnels
Parallel_Lines
So, I used to have a job where occasionally I had to transport cylinders of compressed gas. There was a rule that you couldn't take them through tunnels. So now I'm wondering. Is there a rule about taking a vehicle with a propane cylinder through a tunnel? Is it legal? Do I have to check with each state that I am traveling through? What is the story?
13 REPLIES 13
buta4
Tunnels in Boston, all three of them, NO propane onboard! Take
the surface route bypasses.
Ray
wildmanbaker
ILVMYGT wrote:
Where is the information on the Oregon and Washington tunnels that don't allow propane?
Most do not exclude propane, but require it to be turned off. I continue to be amazed at what people read into things. The one that I know of the excepts propane it not one I would think about taking a Class A Motorhome through
Wildmanbaker
ILVMYGT
2000 Country Coach Magna
CAT 385HP Allison 6sp
1998 Saturn SW2
time2roll
Follow the speed limit and propane off signs and you will be fine.
wildmanbaker
Eisenhower tunnel in Co, several tunnels in Oregon and Washington also.
Wildmanbaker
Dale_Traveling
Got a bunch of stop and check tunnels here in my back yard of south eastern Virginia. Five of them to be exact. All are underwater tunnels. Stop at the inspection station, they check the tank valve(s) and you on your way. Can't speak for I95 further north.
I travel one of the tunnels twice a day to and from work. One morning they stopped all traffic to pull a class A out at the tunnel entrance. They didn't stop at the inspection station.
2006 Hurricane 31D built on a 2006 Ford F53
Parallel_Lines
Thanks, once again you guys knew exactly what I was looking for and gave me the answer I needed!!
Cbones
No problem, just make sure to take the upper level on the bridge.
thomas201
Anyone know the current status on the tunnel under the buildings at the end of the GW bridge into NY City? Over the past 30 years it has changed from the hazardous material route through the city, to under the buildings and back again. Planning a trip up and across the cross Bronx later this year. Haven't been in 10 years. I will cross at about 3 am.
fpresto
The tunnels in Baltimore ban propane. There are signs directing you around and over the bridge. It is an expensive fine and on top of that it is not just a ticket that you can mail in it is a "must appear" ticket. You have to go to court. RVs are easy targets as they know that you probably are carrying propane.
USN Retired
2016 Tiffin Allegro 32 SA
RoyB
In Virginia the tunnels has signs and the general thing to do for RV's is to turn off the PROPANE valves. This may only apply to tunnels that go down a long way where Propane can accumulate I guess... They will inspect to see if the PROPANE is turned OFF and tanks are secured to the frame...
Chesapeake Bay Bridge/Tunnel here in Virginia is the only one I have pulled a trailer through with Propane Tanks and was checked at a very well marked pull-off just before going down into the tunnel.
This is brief summary found on Google about the subjuct...
PROPANE TANKS IN TUNNELS for RV's
Check ahead if you know your route. I think in MD some tunnels in the Baltimore Area on I95 may be prohibited for RV's with propane tanks and you have to route around them... Was that way just a few years back at any rate... The report above may have some info on this - I didn't read it haha...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
jerseyjim
On the PA Turnpike...Northeasst Extension, there is a tunnel. As mentioned by OLD BUSCUIT, there is a very large sign long before the entrance. However...this is only for COMMERICIAL vehicles...not RVs. Been going thru this tunnel without any problems for about 20 years. From popup, TT to motorhome.
Now...the BALTIMORE Tunnel....gotta turn the valves off...and they WILL check it.
Old-Biscuit
YES there are SOME tunnels where the on-board propane source (portable cylinders or permanently mounted tanks) have to be valved out
Those tunnels are East Coast and AL.....and are CLEARLY MARKED with signage LONG before you get to the tunnels.
Tunnels and Propane
And then there are the FERRY SERVICES.......propane source valved out
Ferry Attendants will let you know
