dshinnick
Jun 07, 2019Explorer
OK, after (downstream of) the regulator I have a flexible hose. At the end of the hose is a brass female connector screwed into a male connector about 3/4" wide. This male connector is the end of a brass pipe which feeds the coach. If I could disconnect these two, and somehow connect the male connector, which is the gas input into the coach, to a hose which then connects to a bbq-type propane tank, that would be lovely. What kind of hose would I need, and, this setup would bypass the regulator. Is that a problem? If so, I suppose I'd have to use the Extend-a-stay, which connects before (upstream of) the regulator.
Thoughts?
Thoughts?
38,705 PostsLatest Activity: Jan 24, 2025
