- dverstraExplorerWe leave Michigan and drive a Long Day to get as far south as I can. I then de-winterize at a Full hookup site that has running water. On the way back, if it is really cold where we are headed, I winterize at a campground the night before heading home.
- FULLTIMEWANABEExplorer
Bill/Diana wrote:
All this talk about winterizing has caused it to snow here. I'm about 40 miles north of Philadelphia and we just had a few snow flakes blowing around. STOP IT !!!
Yesterday was shorts weather here in Alberta today it's long pants, socks and even had to put the heating back on. Brrrr. - Bill_DianaExplorerAll this talk about winterizing has caused it to snow here. I'm about 40 miles north of Philadelphia and we just had a few snow flakes blowing around. STOP IT !!!
- Two_JayhawksExplorerWe have done what you described almost every year. We have never felt the need to winterize before coming home. We will stop at a dump station near the home and winterize when we arrive at home.
- MagillaGorillaExplorerA gross question but is has to be asked............
What do you do with "solid" waste if your RV is already winterized? I am guessing that if I flushed it with the pink antifreeze that it would not be the end of the world even if it sat there for the winter. - GoldencrazyExplorerYes. Leave it winterized and use windshield fluid to flush. Use bottled water for drinking. Use disposal eating utensils as much as possible. A little water mixed with the pink stuff in grey tank is ok. Sometimes it is two days until we can unwinterize. When camping in really cold we leave slides in as much as possible. Makes a huge difference and of course a lot easier then in truck stop or rest area. Run generator fairly steady and supplement heat with space heaters as tanks are winterized anyway so no need to worry about getting heat to them. Couple of bottle of windshield washer and bottled water and it works well. Winterize as others do as soon as home but do drain tanks when temps start getting below freezing. Leave valves open and then just add pink stuff when home. I winterized on April 1. !0 bucks of pink stuff is cheap insurance.
- MagillaGorillaExplorerI use to pay to have my RV winterized. I did this until it was done wrong and I had to replace a line in my MH. Since then I have always done it myself.
So my original question is not about how to winterize as much as the process people go through when leaving cold weather and then returning in cold weather.
We are considering leaving Mass in December and then returning in January. I cant really de-winterize it at my house in December because by then I have no access to a hose on the outside of the house. So I figured I would flush the system at a truckstop somewhere in the Virginia area. That part seems straight forward to me. Its the trip home that concerns me. I guess I would have to do it in Florida and then live without water all the way home. - ferndaleflyerExplorer IIIWhen I lived up North I used the DP for skiing all the time and no matter how cold nothing ever froze----but I would add a ceramic heater near the water pump and an extra one in the heated basement. It was also always hooked to shore power or had the generator running. Here in NC outside of a few cold nights I don't turn on the heat all winter---at least thats what the locals call it--WINTER.
- WyoTravelerExplorerIf the temp is below 10 F I am winterized. I just blow out the lines. Takes me about 20 minutes because I have a W/D. If the temp goes above 10 F I dewinterize by taking on water.
- FULLTIMEWANABEExplorerBeen doing it most years since late 1990's leaving freezer box Alberta for Nevada and Arizona for easter breaks of about 3 weeks. Earlier easter is more concerned we are about coming back dewinterized but never ever had a problem. Whilst heading south we leave it winterized (we do it ourselves for less than $15 every year versus being charged $150+ for dealership to do it wrong!). The Antifreeze in the grey and black keep things good there, and we carry water on board in containers for quick strip washes and bathroom use enroute. When we hit around St George Utah area by second night usually, we typically fill up the tanks and flush the lines out.
If we were in depth of winter returning, we for sure would rewinterize before hitting cold temps. It's easy the more you do it with practice and only takes us about 10 to 15 mins to pump all around including washer and outside shower as well as inside faucets, shower and toilet.
FWIW: We kick ourselves when as newbies we paid an arm and a leg to a dealership to do it and every year we started up we had leaks. Not once since doing it ourselves have we had any split pipes or over tightened plastic nuts. You don't know what you don't know eh?
About Motorhome Group
38,764 PostsLatest Activity: Dec 23, 2025
