ROYBUCK's avatar
ROYBUCK
Radiator Hose
Starting to get everything together to change coolant. I don't want to remove the Radiator hoses until I have new ones, where can I get the number for the hoses, and where to purchase, will I need to get these from Monaco or Cummins or else where. Thanks Roy
  • i went to kenworth and bought a foot of hose 2.5 in straight hose and cut to lenght on my Newmar DP still had enough extra for a spare...
  • Freightliner Parts 1 864 206-8584
    They will look up the exact parts for your chassis from their production records. I bought all of my hoses from them when I changed coolant.
    One tip if you're planning to change the 2 thermostats. I just went to the cat dealer and asked for thermostats for a cat 3126 engine. Later I determined that I removed 180 degree thermostats and installed new 190 degree thermostats.
    Fred
  • With your vin# your chassis builder should be able to set you up with the right hoses.
