overdrive75's avatar
overdrive75
Rear Axle Fluid Change Differential Cover with drain plug.
So here is the scoop, our 2003 Winnebago 29B is built on a 2003 Ford E-450 chassis. I am doing my annual maintaince, and decided this year is the year to fix my rear end seepage from between the diff cover and the diff. Chassis has 44,000 miles on it, so not a ton. Fluid is pretty stinky and black in there as well. So owners manual says 80W90 oil for the axle. I have a case of 80W90 synthetic on the way. Also have a case of 75W140 Motorcraft on the way as that is what goes in the diff on the towed car (2003 Explorer). So question what fluid is everyone running in there. Owners manual says 80W90, best I can find is 50k mile change interval, so I am almost at that. All this said being a 4.56 I bet this axle runs hot, so was looking to swap covers out for one with a drain plug. Has anyone done this? Which cover are you using? Also what oil is everyone using in there? Thanks
