k_jensen6's avatar
k_jensen6
Rear slide sticking
We have a 2001 Imperial and the bedroom slide has started sticking when we retract it. It's the same spot, about 6" from the full position. If push/lean on it, it will go in. I've cleaned the gears and sprayed the dry lube on the track but that is not the cause. Any advice?
See other thread posted.
  • If your bed is part of the slide you may have something under the bed holding it.
