cappi1976 wrote:
- Spray foam is my ideal on the way I am thinking about going, I also plan on doing a very thin layer before the spray foam just for the airtight water proofing idea.
Closed cell spray foam
IS a good water/moisture barrier if properly applied.
The problem with spray foam, is that it expands uncontrollably. Not enough in some areas and WAY TOO MUCH in most. This requires that you cut it back before installing the interior finish wall board.
cappi1976 wrote:
- The house side I am fairly confident in that rebuild part as I got some people that owe me favors and usually, I can find items for really cheap or free.
So questionable quality ??!!!!
cappi1976 wrote:
But I do need to look into what bolt to use for the manifold.
Inconel - This is a special grade of stainless steel designed specifically to withstand high temperatures and corrosion. Used in the jet engines and space craft industry and by some custom header manufacturers.
Open your wallet VERY WIDE !
