- Old-BiscuitExplorer IIIWhat Brand/model of fridge?
Is fridge in 'auto'....if in Gas mode it will not switch to electric
Is it in 'limp mode' it will not switch if it is
Have you checked that 120V AC is available...if not it won't switch?
If you have 120V AC have you checked the 5A fuse on control module......if blown it won't switch. - tropical36Explorer
GHOST1750 wrote:
Why isn't my refrigerator switching to Electric from gas?
Is your auto button on with the fridge controls and assuming that you do have power? Check your breaker panel as well for any that might be tripped. - Dale_TravelingExplorer IIAgree with enblethen, no power. Besides a tripped breaker don't forget GFI outlets could be in the circuit.
- No 120 volts AC available.
Verify that you have 120 volts to rig
Check receptacle in the exterior access to refer for power. Use a known good device. No power could be tripped circuit breaker in 120 volt AC distribution panel.
About Motorhome Group
38,769 PostsLatest Activity: Dec 31, 2014
