- lmcgillExplorer
donsuefuggrwe wrote:
How do I remove the the drivers electric power seat to repair wires that control it. They are pretty well hidden under it.
Did you get the wires fixed? I had a problem this weekend when I turned our chair around and pulled out all the wires including one crimped pair under the seat I can't reach. Looks like I will be taking some bolts out. - Johno02ExplorerSee if seat is attached to pedestal with four bolts, one on each corner. remove these four, disconnect powerplug, and lift seat off and out of the say. Repair wires as necessary and replace. Pedestal is usually welded to floor, seat attaches on top. Recline motors are built into seat.
- desobelmanExplorerDon,
I suggest you post this on the National Owners forum on iRV2.com. More likely to get a better answer there.
Also, check out the local National Owners Club FMCA Chapter near you and join it! Talk about lots of information and expertise about NRV products! plus, a great bunch of members, all willing to help a fellow NRV owner!
Happy Trails! :W
Darryl - midnightsadieExplorer IIfind the bolts under the carpet the electric should have a plug. don,t forget the safty belt.
About Motorhome Group
38,708 PostsLatest Activity: Mar 04, 2025
