- pauldubExplorerYou can squirt expanding foam in the hole. Trim it after it hardens and then cover it with Eternabond if you're talking about the roof. Maybe you're asking about the hole on the ceiling inside?
- Triker33ExplorerHave a Trav'ler installed and they will take off the old one.
The crank up Batwing is still good to use. You may want to keep that one.
New OTA antennas are no better then that one.
About Motorhome Group
38,705 PostsLatest Activity: Jan 23, 2012
