RockBottomRacin's avatar
Oct 05, 2017
Removing trans on 1993 Ford Class C, looking for resources
Do a trans swap for a friend of the family, 1993 Ford E350 Tioga, 460 with an E40D trans, she bought a reman and asked me to swap it. I've done dozens of dodge and Chevy over the years but I've never done a Ford, looking for some resources, or a write up with pictures? Can anyone link me to something helpful? Been searching without much luck.
Thanks guys!
1 Reply
  • DrewE's avatar
    DrewE
    It should not be any different from a similar vintage ordinary van, of which there are a gazillion on the road. Finding a write-up or YouTube video about them shouldn't be too terribly hard.
    Here is one write-up that seemed reasonably thorough, though I can't vouch for accuracy nor suss out exactly what years it was referring to. It also isn't for an E40D specifically. In any case it ought to be pretty straightforward, aside from the obvious difficulties like the fact that the transmission is quite a heavy beast.
    If this motorhome has the driveshaft mounted parking/emergency brake setup, it would also be wise to look up the info on that contraption as well. It's bolted onto the output end of the transmission. I suspect that you don't have this brake setup, though, but I'm not positive.
