โAug-21-2017 08:12 AM
โAug-21-2017 08:16 PM
FIRE UP wrote:
Or you could go on a road trip of sorts...
Commically, I agree. But, I don't know how much you've traveled lately but, the roads in America are somewhat less than desireable. We just returned from a 6,400 mile trip around the U.S. and, I'm not sure how or why, I've still got cabinets hanging on our coach walls. Or that I haven't developed a leak in my rusty '04 Itasca Horizon diesel fuel tank. Some of those roads were SERIOUSLY bad, mostly in Michigan.
So the OP, while making a more expensive choice by replacing his tank, is making a smart one. None of us likes this sort of thing. Unfortunately, it happens from time to time. One meets the problem head on and, make an informed decision on a course of action that will help in keeping the coach on the road, or in an RV camp, wherever is chosen.
Scott
โAug-21-2017 02:20 PM
โAug-21-2017 12:47 PM
Tom/Barb wrote:
My big concern is draining the tank and storing the 120 gallons of diesel while I pull the tank.
If I'm going to pull the tank, I'll replace it.
So I guess When there is no magical easy fix, I'll buy the new tank, transfer the fuel to it setting out of the coach, jack the coach, remove the old tank, transfer the fuel back to it, then install the new tank, and fill it from the old tank.
And to add, I'd never drive a diesel leaking coach to a camp ground.
I have a drip pan under the area now, and caught less than a half a cup of fuel in 3 days after the epoxy patch.
So it is still leaking after I placed the patch on it.
โAug-21-2017 12:42 PM
โAug-21-2017 11:55 AM
โAug-21-2017 09:59 AM
โAug-21-2017 09:41 AM
โAug-21-2017 09:38 AM
Tom/Barb wrote:
Our Newmars fuel tank has a 1/2" long crack in the bottom of the tank. It drips about 1 drop in 2 minutes. Yes it is full of fuel.
To drop the tank requires a pit, or jacking the coach very high. requires 36" clearance under the coach, we have done that once, didn't like it.
How would you repair the tank? the tank is aluminum, welding is an option, but requires the tank to be removed and purged. I've welded diesel fuel tanks before but I time they will crack again beside the weld.
I now have an EPOXY patch on it, to stop the drip. but don't trust it to stay. ( the tank flexes that is what caused the crack)
Anyway Ideas ?
โAug-21-2017 09:34 AM
โAug-21-2017 09:03 AM
Retired JSO wrote:
I'd try welding the crack, grind flat then weld, a larger metal patch across the bottom where the tank flexes. We also had a 2000 NMMA 4092 on a Spartan with a 150 gallon tank but never experienced a fuel leak. Just air bags, and ball joints.
โAug-21-2017 08:34 AM
