Jan-21-2019 01:59 PM
Jan-27-2019 05:30 AM
tropical36 wrote:Thanks. I agree on possible repair, but I don't have any intel on what kind of system it has, condition, or how tough it will be to install. The ATS I sent offers some built in surge protection as a bonus so might be worth the work to install anyway. Beats having it unused in my garage.Mile High wrote:
That transfer switch is on the way David - Hope it works out for him and everything fits!
Very generous of you, but have to wonder if the OP, has even bothered to look inside the switch, during all this time and during discussion. That said, it's much easier, replacing parts in these switches, than for replacing the whole thing in many cases, so maybe the parts or short wire runs, can be utilized. Still making a bet on the loose connections and crystallized wiring, as being the culprit or initially so.
Jan-26-2019 07:31 PM
Jan-26-2019 12:21 PM
Jan-25-2019 12:23 PM
Jan-24-2019 08:19 AM
Tom/Barb wrote:DrewE wrote:
What exactly do you mean by "reversed polarity"? .
Substitute the red or black wire with the white at the pole. it sure fried ours.
but it also fried the inverter/converter.
$4500. later we had a rewired coach with new inverter/converter, transfer switch, and surge protector.
Jan-24-2019 07:40 AM
Bumpyroad wrote:larry cad wrote:
No, not true. My son's first motorhome had a manual transfer switch. It had a knob mounted on the outside of the box that you could use to switch between shore and genny power.
so on your son's MH he could connect two sources of power to the rv at once? didn't the "switch" automatically switch sources when the kob was moved?
bumpy
Jan-23-2019 02:52 PM
wa8yxm wrote:Or even less dramatic than that - you're away, the power goes out, and your Onan autostart starts the generator and the ATS restores power. You get back and the dog is still basking in air conditioning! Can't do that without an automatic transfer switch 🙂camperdave wrote:
What's the point of the transfer switch? When would you ever run the generator while plugged in? just wondering. My rig is wired like you are suggesting, there is a generator outlet I plug the shore cord into when driving, then plug it into the pedestal when at camp.
Ok.. You pull into a park (have done this)
it starts Raining (Seen that happen too)
Some Ten T type (His license plate is 1 D 10 T) spins out on the wet pavement and WHAM hits a tall creosote soaked post and down come the high tension power lines (Well actually. it was not raining. he did not spin out (he just did not turn. the road turned but he did not and BANG.. NO POWER.
OR the Construction worker on the back hoe (Happened to me twice. once in college. once in campground)
Or the Hurricane comes calling (Been there too)
Well it's like 2 Am and you need power cause it's hot/cold and no way on earth do I want to go out in that rain and play with the power plug to transfer from Shore to Generator.
The ATS does it for me.
Jan-23-2019 02:39 PM
Jan-23-2019 01:35 PM
Jan-23-2019 12:18 PM
Tom/Barb wrote:
When / IF your transfer switch has ever been hooked up to reverse polarity it's over there is no fix. they are after all a magnetic relay. destroy the magnet destroy the relay,.
Jan-23-2019 12:10 PM
Jan-23-2019 12:08 PM
Jan-23-2019 10:46 AM
hertfordnc wrote:Please post what you find when you get on-site for a review.time2roll wrote:
Nothing wrong with putting an outlet/connector on the generator that matches the main cord. Although you will probably be half way to the cost of a new switch by the time you do it properly.
+1 to unplug and inspect the existing switch before spending money.
For all we know the pedestal supply could be bad. Maybe have the RV park take a quick look before you go out there.
Initially he thought it was the park power. But his problems were intermittent.
It went from no power from the pole- then he got power to half his coach - then he switched to the generator and he had all power everywhere.
So the park moved his site (apparently the maintenance guy can't meter the pole)
This went on for a few weeks with intermittent success.
Finally, when the coach would not take power from the generator and when he called me to discuss it, we started to think it's the transfer switch.
SO i'm thinking at some point the TS was not fully switching both lines? That would explain the partial power, right?
And then it was not switching at all and defaulting to the generator?
And then it failed completely and created an open. ut i think we have a paln to get a new TS and I'l get up there in the next couple weeks to install it.
I love what a thorough discussion this forum has when you ask a question in January 🙂
Jan-23-2019 10:26 AM
