kiloo9's avatar
kiloo9
Replaceing tv and console
I am in the process of replacing the tv and modifying the console on a 04 Holiday Rambler Vacationer.
there is a wire sensor and a protecting cover under the console the cover is deteriorated and would like to replace it. I have no idea what component is this nor what it's purpose it is. I have call a couple of places and no body can help. I would appreciate if some body out there is familiar with this gadget and can help.
Thank you and you'll have a great day.
Jose
  • Thanks for the info, found both sensors thanks, will see if I can find the mounting plastic bracket and cover. Take care and happy Rving!
  • When I replaced the TV on my 2005 HR Ambassador, I had a sensor mounted to the bottom of my console. It sensed the temp for the front a/c thermostat. It was not accurate by any means because of the heat coming through the windshield. I moved mine over to the pass side cabinet and it worked much better. There was also 1 mounted in the bedroom, above the bed for the rear a/c.
  • Im not sure on senior. But HR I think is close to the Mandalay. I can send you pics of what I did. I removed the frame that held old TV. Used a swing out mount. Came out great and sits back further. I fit a 42 inch.
    Good Luck
  • kiloo9 wrote:
    Hello Jerry I just send you a picture to your email, hope you don't mine.
    I don't mind Jose. But I did not get any pic. Try again.
    Jerry
  • Hello Jerry I just send you a picture to your email, hope you don't mine.
  • I have a picture but for some reason I can not up load it.
