โApr-19-2015 08:22 AM
โApr-19-2015 11:58 AM
tropical36 wrote:
There is so much talk about good and bad tires and ones that will blow out opposed to the ones that won't blow out. Now, tell me someone, does the US Dept. of Transportation (DOT) number on the tire, mean nothing at all, or is there something I'm missing here?
As for where tires are made, every company is seeking the most profit and along with a few diehards, I betting that it won't be long that every tire will be made in China or some other place, out of the US.
Speaking of blowouts, I'm guessing that they are caused by under inflation (purposefully or slow leak) or some road hazard and not much matters, as to who might have manufactured the tire.
โApr-19-2015 11:35 AM
โApr-19-2015 10:53 AM
โApr-19-2015 10:49 AM
hsteinle wrote:
You pay more for them BUT I personally think it is hard to beat the Michelin tires for a motorhome. There is just TOO much to lose with a blowout. Michelin tires may cost more, but it is difficult to put a price on protecting one and their family. By using the FMCA Michelin Advantage program, you can acquire mh tires at a price lower than even a dealer can purchase them. Again, just my personal opinion.
โApr-19-2015 10:47 AM
1BryNelson wrote:
First have you looked and priced Toyo tires? If you are driving as stated the Toyo highway truck tires might be better priced. Live mostly in AZ so I use the those. When I shopped around rhose were the best price and tire. Like previous post about tire shielding, gonna do that myself. Heat in AZ is a ongoing problem, but rather that than snow.
โApr-19-2015 10:18 AM
โApr-19-2015 09:48 AM
S'NotFree wrote:
After seeing pics of the recent band tour bus fire (total loss) due to blowout, I realize my tires should be replaced because of time not wear. I am thinking Cooper commercial truck tires instead of RV tires for the $ difference.
I know this has been covered in past. I called Cooper and was connected to their commercial tire specialist. He says that they sell a lot of tires to Motorhome owners. I currently have 275/70R/19.5 load range G. He asked me how I use coach and where and He recommended same size in their load range H in their Roadmaster 170 series. He would recommend something else if you drove in snow or muddy dirt roads. He said if I weigh the axles and call him. He will give me the correct psi to run and that I should get the same ride as the G range with the proper psi in the tires plus have a much stronger sidewall.
Also, asked him about UV protection in this tire, he said cover them of course, but also mentioned that sometimes the covers you buy that covers the entire tire make the tire much hotter causing more damage than UV and suggests some type of sun protection that blocks sun but allow air flow to keep tire cooler. Is there anything like that you can buy like something that attaches to wheel well and hangs down or do you jerry rig?
Anyone used these tires and if so your thoughts?
Thanks
โApr-19-2015 09:05 AM
โApr-19-2015 08:36 AM
