Replacing Batteries Questions
terryb149
I need to replace my two chassis batteries on my 2006 Allegro Bus. They are so dead, not even a jump start worked.
Question....are they 12 volt or 6 volt batteries? Anyone know? Any recommendations as far as what size I need or type to buy?
I'm trying to save some money here by doing it myself. How hard is it to do this? I will be needing to remove the four coach batteries in order to get to the engine batteries. Anything to watch out for?
Thanks in advance for the help.
11 REPLIES 11
Bumpyroad
wa8yxm wrote:
First, mark the positive cables clearly I suggest RED paint or nail polish
or get a set of cable marking stickers and identify them all separately recording the location of 1, 2,etc.
bumpy
acker1
I took a lot of pics, numbered the batteries, then labeled each wire.
Example: 1+, 4- etc. Sure helped when I put the new ones in. Did the same on a golf cart at the state park we are at. That REALLY helped as earlier on people added 12V things so a manual was not too helpful.
DICK
40' 2010 Phaeton QTH
toad--2013 GMC Sierra Crew Cab pickup 4X4
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
wa8yxm
Generally the chassis batteries are 12 volt but there is no guarantee, they also use both six and 24 volt depending on the chassis.
Best option is to do this.
Photograph and remove the batteries to the battery store
That way you only need to make one trip (Other wise you make one to get them and another for the CORE refund.)
filadelfia
Suggest you watch the youtube video HOW TO REPLACE DEEP CYCLE RV "HOUSE" BATTERIES, The video also covers chassis batteries.
Good Luck Don
Teacher_s_Pet
1st take a couple of digital photos of the wiring on ALL of all 6 batteries. If your Bus set up like our '06 Phaeton, I had to pull the 2 6Volt batteries toward the front of the RV completely out of the compartment. Next take out the 12V battery toward the front of the RV, then slide toward the front of the RV the rear most 12Volt battery and remove. Install in reverse. Our OEM 12Volt starting batteries only lasted about 4 years of fulltiming, OEM house batteries lasted a little over 5 years. We're working on 10 years in the Phaeton now, so the cycle is overdue to start again.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
gbopp
Definitely take a picture of the batteries and wires BEFORE you disconnect or remove anything.
This can save you a lot of frustration.
PF_PM
Clean all the connections before reassemble ..
2005 Newmar 34' Kountry Star, 8.1L W22, Blue Ox 10K, Honda Pilot, Bijon Shitzu (Sassy) dash dog. Nine Provinces, Two Territories, 47 States, Northern Mexico... so far..
RoyB
If they are two batteries mounted in SERIES then they are two each 6VDC BATTERIES. If they are wired together in parallel then they are two each 12VDC batteries...
Everyone should have a multimter to measure such things...
Go pick up one from HARBOR FRIEGHT. Usually free when you purchase something from them...
I would take a CELL PHONE photo of how they are wired up before you remove them...
You also need to learn what made them run down... Your new ones will do the same thing...
Hopefully you have a smart mode converter/charger system with your RV that uses the multiple DC VOLTAGES to keep your batteries re-charged when connected to shoe power or running from your generator.
Some of the older RV UNITS only have single mode converter/chargers and this 13.6VDC only charging voltage may boil out your battery fluids over time which ruins then eventually.
When parked you should have a battery disconnect method to keep the parasitic drains in your RV from draining down the batteries...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Golden_HVAC
Make sure that the coach is unplugged, because the power 'converter' can put 12 volt power to the battery terminals if the RV is plugged in.
Mark all the wires carefully, and battery locations. Take pictures too.
Disconnect the - terminal wires for all 6 batteries, then you can start to remove the interconnecting wires.
The batteries will all be heavy, you will feel like you did a workout. My golf cart batteries are 67 pounds each.
Your chassis batteries most likely will be 12 volt, and probably group 31 or larger battery. If it is a 8D battery, it will be in the 120 pound range!
Once you have disconnected and removed the 4 coach batteries, then starting the engine is not a option, unless all the + 12 volt wires are safely wrapped up, so they can not short to ground (with engine running) until everything is put back together.
If the battery is about 18" long and 10" wide, 8-9" tall, it is the 8D monster 120 pound battery. If it looks like a normal car battery, but slightly larger, then it probably is a group 27, group 31, or similar 60 - 70 pound battery. It should be able to be found at Costco for a good price, or any auto parts store. You want to get a good battery, with a 60 month warranty. Anything less will not produce the 300+ cranking amps that each battery will put out to start that large engine of yours!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
2oldman
12v. Same size as in there now. Only difficulty is lifting. We get a lot of posts from folks who don't pay attention to how the batteries are wired up BEFORE they remove them.
Bumpyroad
are they hooked in parallel or series?
bumpy
