- MargaretRehkopExplorerDealing with a rat infestation can be extremely difficult if you are not equipped with the correct information and experience. When my uncle faced the rodent infestation he used live traps, as he was against of causing any harm to them. But when the infestation spread on a large scale he called the http://www.eg-exterminatorsnj.com/Rats-and-Mice-Extermination.html professionals to help him control the situation. They helped him a lot and also told the ways to avoid this problem in the future.
- wvabeerExplorerPoison and seal it up so they cannot get in.
- johnhicksExplorerI used fox urine pellets back in Texas to keep the critters away. A bit stinky but worked.
- rgatijnet1Explorer IIIWhat I have used for years is Coyote urine. It can be purchased online and using a spray bottle I spray it on the tire base, the levelers, and the power cord. This keeps squirrels, rats, mice and other small rodents away from the coach. Depending on the weather/rain, a spray usually lasts about a month.
I don't worry about things on the inside since I stop the pests on the outside.
And no, it is not an offensive odor to humans and my big dog just took one smell and basically ignored it from then on. Of course she is much bigger than any coyote. :B - Romer1Explorer
janstey58 wrote:
PURE Peppermint oil from GNC soaked into cotton balls has worked flawlessly in my rural RV barn stored DP for many years. Some dispute it, but I can tell you it works for me. And in the Spring, the RV smells very nice!
x2.
But don't get carried away with it, and you do have to leave the windows open for a day in the spring. - mat60Explorer
rockhillmanor wrote:
.....No wonder I feel like **** after I put moth balls in my TT tonight... I hate the smell but I didn't get a new camper to have mice make a mess out of it this winter.
I seriously would not use mothballs in an RV.
Moth balls are toxic to humans and 'especially' if you have children. Add them to the small confines of an RV and they are even more harmful to you and your family's health.
snip it:
mothballs contains 396 grams of naphthalene, which is sufficient to raise the average residential indoor air concentration to approximately 200 micrograms per cubic meter over a period of 1 year, though in small homes or apartments this would be expected to be much higher. Exposures of this magnitude are commensurate with industrial exposures to ... jet fuels.” (rv's are 1/4 that sq footage)
Babies are especially vulnerable because their bodies are less able to clear naphthalene byproducts formed in blood.
they’re a health hazard for kids for several reasons. Naphthalene exposure can cause red blood cells to break apart, a condition known as hemolytic anemia. Just the slight smell of a moth ball cuts my airways off and puts me in the hospital.
Mouse and bug control in an RV.
At night turn your inside RV lights on and crawl underneath your RV.
You will be shocked how much light will be shining thru all the holes left behind by the manufacturer. You need to fill all these holes with Great Stuff or whatever. That is what will stop the mice from coming in.
In a MH be sure to have ALL your heating/ac turned off so the vents are closed before you shut off the motor. - rockhillmanorExplorer III seriously would not use mothballs in an RV.
snip it:
In a MH be sure to have ALL your heating/ac turned off so the vents are closed before you shut off the motor. - wildmanbakerExplorer
georgelesley wrote:
If it is a motorhome and since you call it a coach I assume it is, the best defense is to make it impossible for them to get into the coach. The only points of entry where they can climb in are points that touch the ground. Tires, cords, hoses, etc. since they cannot jump any distance, if those areas are protected, they cannot get into the suspension, motor, etc, etc.
When ours is not in use but plugged in, I hang the cord up off the pad. You can also get cones to put on the cord similiar to what ships use. To protect the tires I park on aluminum flashing coated with car wax. It is too slippery for them to climb on the tires and gain access. Just cut the flashing a few inches bigger than the tire footprint.
I have also put a ring of traps around each tire which again denies access. Both methods work as we have not had any mice in several years since adopting these methods. If one you are so inclined, doing a combination of both methods would be double protection. I wipe the flashing off with a damp cloth before each parking to keep it slick.
We did also note that fewer mice got in when we installed the tire covers. I assume the vinyl cover blocked some, but not all. A few smart ones still climbed up the inside facing tire area.
We did try all the moth balls, dryer sheets, etc. all seemed to work some, but areas like the engine compartment, generator, etc are hard to protect that way and may require frequent changing to be effective. Not allowing them to get in seems to be the easiest.
You can also try urine from predatorpee.com sprinkle some around the tires and that will also help, but does require reapplication every few months or so. I use it to keep them off the deck at home around the BBQ area.
WOW! Really? I guest the rodents West of the Mississippi are in better shape than yours are. I have had them jump a good 3 feet, 2 feet vertically before, and it really surprized me. I was disposing of 3 mouse carcauses near evening, into a dumpster, and they proceeded to jump out, and all over me. Granted they did not stay long, but I was not expecting this to happen. I guess what ever works for a person.... - georgelesleyExplorerIf it is a motorhome and since you call it a coach I assume it is, the best defense is to make it impossible for them to get into the coach. The only points of entry where they can climb in are points that touch the ground. Tires, cords, hoses, etc. since they cannot jump any distance, if those areas are protected, they cannot get into the suspension, motor, etc, etc.
You can also try urine from predatorpee.com sprinkle some around the tires and that will also help, but does require reapplication every few months or so. I use it to keep them off the deck at home around the BBQ area. - wildmanbakerExplorerWell, this is a good question with no pat answer. Mothballs do work, but are toxic, and it is hard to great rid of the odor they leave behind. I had put them everywhere inside and in the basement areas after we got mice on a winter camping trip. No single thing seems to work. Traps, sticky boards, sound generators. Fresh Cab seems to work, and no, we have not had the rodents eat them. Cats seem to help, as they seem to encourage the mice to leave after they have entered. We have had them in the ceiling chewing the foam and other areas. The seem to gain access to the basement, travel through the heating duct into the upstairs, or up the back of the refrigerator, into the ceiling. Most Class A MHs have a basement so finding the access points using light is a pretty much a loosing exercise. Using screen to plug holes sounds good, has anyone ever had wiring damage from rodents?
About Motorhome Group
38,708 PostsLatest Activity: Mar 06, 2025
