Aug-30-2015 02:21 PM
Sep-01-2015 01:11 PM
Sep-01-2015 09:49 AM
Aug-31-2015 03:23 PM
SkyCop4U wrote:
The generator does not like the spike. It is a 8 KW BTW. lots of power.
Aug-31-2015 01:49 PM
dougrainer wrote:Bill.Satellite wrote:
How large (small) is your genset? A 50 amp system would need at least a 6000K genset but since there is also a "surge" factor it might take 7-8K to simply break even. I have a 15K genset on board and have never encountered a similar issue but I certainly can see where this could be an issue.
A Genset 5.5 or larger has more than enough power to start and run 2 AC units. Doug
Aug-31-2015 01:47 PM
Aug-30-2015 06:26 PM
Aug-30-2015 06:25 PM
Aug-30-2015 05:44 PM
wolfe10 wrote:
Sounds like a bad capacitor (at least you hope so). With all power off, go up on the roof, remove the cover and then access the "electrical area". Check capacitors for swelling, discoloration or leakage. Be sure to discharge by shorting terminals before removing. Any HVAC store should have capacitors to match.
Could it be the compressor-- yes, but check the cheap stuff first!
Aug-30-2015 04:39 PM
Aug-30-2015 04:14 PM
Aug-30-2015 04:08 PM
Aug-30-2015 02:46 PM
