angler's avatar
angler
Run Flat on back dually
Had the oil changed and when they checked the tires the back inside dually was flat. Tire was check and deemed unusable. Could have been flat a while. I should be more proactive on checking the inside tires. You may chastise me for that if you wish:)
Anyway I had the trucking shop put a new tire on the dually in back and then I started reading that that may not have been the best option.
My thought is I would have to buy another tire put both new ones on the steer tires and the fronts on the back since the new tire has much more tread depth it could cause issues. Use the tire that wasn't flat but was handling most of the weight as a spare.
Is that the right thing to do? I'm checking the date codes to see how old the other tires are, but I think they are about 4 years old.
