- jorbill2orExplorer IIThe short answer ...No .. You'll drain almost any battery bank in minutes ..even if the inverter was large enough.
- RoyBExplorer IIIMO Running 175 DC AMPS or more from your battery bank just doesn't seem like the wise thing to do.
This will run down a single battery is just a few minutes...
Roy Ken - naturistNomad
+1
(a) a 2000 watt power supply of any sort is marginal for the standard 13,500 BTU RV AC unit
(b) As @jorbill2or said, a realistic RV battery bank of 1 or 2 6v or 12 v batteries will be sucked dry in minutes. There just isn't enough energy in 'em to handle a useful AC run. - Sure.... for maybe 30 minutes assuming you have the proper 400+ amp hours of battery to properly run a 2000w inverter.
On edit:
My Prosine 1800 easily runs my 13.5 Dometic. Starts as smooth as utility power. I forget the amps but it was less than the microwave. Just ran as a test. - Explain why you want to do that. Do you have a Genset? Doug
- wolfe10Explorer
And want to take 4 times as long running your generator to recharge the batteries. AND don't particularly care about battery life.
As said, it is not practical. - dons2346ExplorerYour AC units probably are not wired through your inverter so no you can't in your present configuration. Even if you changed the wiring, the inverter will not power the AC
- MrWizardModeratorIf you are an engineer
If you have a truck load of batteries
If you have a small 5000BTU a/c
Then you can cool the closed off bedroom for a few hours at night
And run the generator all day the next day to recharge them
In 99.9% of the time....It just ain't practical - Sully2Exploreranswer is NOPE!
- Dog_TrainerExplorerI have a 3000 watt inverter powered by 6 batteries that gives me just over 400 amp hours at 1/2 full charge. With all of that I cannot run the air for any reasonable amount of time
About Motorhome Group
38,705 PostsLatest Activity: Jan 14, 2025
