Buster52
Aug 03, 2014Explorer
Running both A/Cs
I just bought a 1989 Southwind. The generator needed some work (both the control and voltage regulator needed replacing) so I was using the A/Cs to put a load on the it. It is a 6.5kw Onan and should have plenty of power. But as soon as I try to use the second A/C the gen dies. It will work on ether A/C but not both. There is no other load on the system. There is a selection box that will not allow more then one to run at a time when on shore power. Is there something I am missing? 6.5kw should be enough power or wouldn't have a 4kw generator.
