BillHoughton wrote:
This implies that there is something up there to which I can attach screws/tacks. Well, that'll be another fun project, unless I succumb and let an upholstery shop invade my wallet.
As I said before on My Winnie I had the same problem,there is Lauan under the fabric and I first started with the
Headliner Repair Caps they screwed into the Lauan and worked for a while. The problem was that the it started in a very small area but as time went on the foam and adhesive just started to come loose in larger areas. It is a stop gap that may work out for you if it doesn't get any larger.
If it does then you may have to do as I did and take it all down.
Good luck!
