We have the Winegard RM-DM46 crank up antenna on our MH. It's an 18 inch dish, which can only receive standard definition channels (no HD). That's OK with us, as we don't watch much TV when we travel.
Here's the method I use to aim the antenna, which is a bit different from the official instructions:
Once parked in the campsite, I walk about 15 feet from the front of the MH to get away from the magnetic field distortion caused by all the metal in the MH. I then sight along the center of my compass and the side of the MH and rotate the azimuth ring on the compass until the north arrow is over north on the compass. In the picture below, the rear of our MH was facing 160 degrees.
Once I know which direction the MH is facing, I go inside and rotate the azimuth ring on the antenna to that direction (in this example, 160 degrees as in the picture below). I then crank up the antenna to the elevation for the local ZIP Code. The elevation displays in the elevation sensor readout, which is on the right in the picture. BTW, the red clip on the crank goes on the gear shift so we don't drive off with the antenna raised.
Once the antenna is raised, I rotate the antenna to the azimuth for the local ZIP Code. In the picture below, this was 240 degrees. I then use the Dish Pointing/Signal Strength meter to find the exact direction and/or elevation that gives the strongest signal for the satellite. Most of the time, I find the satellite and get a strong signal with only a minute or so of tweaking. There have been a number of occasions when I get it just right with no tweaking at all.
Since the antenna only receives standard definition channels, we always go to Settings and select Hide HD Channels. This gets rid of the 771 - No Satellite Signal messages if we were to change to an HD channel.
