If you want to watch TV driving down the road with the grandkids then you should have the necessary DVD's on board or record a bunch of kids programming before you leave. This will allow you to have the kids watch uninterrupted programming no matter where you are and how many trees you might encounter. No dome will allow you to watch DirecTV HD and no dome will allow you to watch different programs coming from different satellites (Dish and DirecTV use 3 different satellites to receive all of their programming). In motion is great but it has many, many draw backs. Watching previously recorded programming has no limitations and can be viewed anywhere, anytime under any conditions.
Dome antennas from every manufacturer has many limitations. The Winegard Trav'ler (the open face antenna that folds down for travel) has only 1 limitation and that is the ability to watch live TV while driving down the road. Even that option is limited if you pass under a bridge, beside a tree or light pole or drive through a tunnel. If you travel exclusively in the SW where there are few, if any trees, this is not an issue. If you plan to travel any of the Northern US, it can be a very serious issue.
