brabono's avatar
brabono
Seabreeze
Construction of walls in 2006 seabreeze. Water leaks need to be repaired. What is inside wLl bt drivers windoe
  • I suggest you pose this question on irv2.com in the National RV Owners section. Much more likely to get a precise answer.
    Also, do not attempt to write in shorthand. Spell everything out in detail. That helps readers understand exactly what you are talking about and can answer faster and better.
