Branson N Tucson wrote:
Have a question on how long is a reasonable time to replace the Serpentine belt on a Cat C-7 engine. It's been 28,000 miles since it was last replaced. Had one break and had a bill of $1,999.00 because it locked up the air condition condenser.
Thanks for your recommendations.
Branson,
Yep, me too on "...locked up the air conditioning condenser....". Now, first thing that's needed is:
year/make/model/chassis etc. that we're dealing with here. Lots of coaches were fitted with the C-7 and, in all three versions. The 300, 330 and 350HP versions. Depending on which model coach, length etc, replacing that Serpentine belt might not be too bad. But, on some, it's quite a job. Since 99.999999% of the coaches fitted with the C-7 are rear radiator, as stated, some can be a real bear to work on.
A good RV diesel tech, might be able to have the old belt off and the new one on in as little as 15-20 minutes, again, depending on access to it. But, even the best techs can be thrown for a loop in some of these coaches.
Scott
