kemer's avatar
kemer
Side mirror turn cameras
I have a 2014 Winnebago Sightseer. All of a sudden for no apparent reason when I put either turn signal on, the camera isn't sending a view to my screen. Also, at or about the same time, the horn stopped working. I'm thinking the horn might be a fuse issue, not sure why cameras quit working. Suggestions? THANKS
  • there are trigger wires for Left, right, reverse.
    Now can you guess what / where the trigger wires come from ????????
    Of course, turn signals and if course the Reverse light.
    These wires are fed to the camera.
  • Take a look at the settings in the display. If the rear camera polarity is set to ground, it all acts pretty weirdly. Reset it to battery. Worked for me.
    HTH
  • Same loss of camera ~ sig vehicle~. Gotta bunch of wires hanging down from Passenger dash. If not careful have loosened couple of connections with my feet. Can feel where comes in from camera.
    JM2¢ ~~ YMMV
  • Check the fuses?
    If one blew you'll need to figure out why. Maybe just too many things going through it.
    Good luck,
    Scott
