- opnspacesNavigator IIOpen the coach door and see if the top of one of the steps is screwed down. The battery might be under there.
- way2rollNavigator IIDid you mean Freelander? Likely in a bin or under the steps. Do you have your battery disconnect turned on? Have you tried plugging in to shore power?
- bobndotExplorer IILook into finding the location of the slide-out relay or fuse.
Depending how the wires run to your slide, a wire could have been pinched by the slides movement.
Check youtube , there are tons of slideout repair vids.
About Motorhome Group
38,705 PostsLatest Activity: Jan 14, 2025
