southman's avatar
southman
slide maintanace
have 2 slides on my Coachman leprechaun. I have seen slide spray to keep the slide running smoother as well was spray for the seals. Are all of these actually needed or are they just marketing sales tactics.
  • Check the owner's manual for your slides. Ours says the only maintenance needed is to check the rails clear of debris.
    -Michael
  • I used the spray on my slide gears. It stuck so well that it stuck a small rock to the gear teeth causing the rock to break the gear when it meshed with the drive gears. That would not have happen if I didn't use the spray. Never used it again with no more problems.
