extras's avatar
extras
Slide out
What is needed to service the slide out on a 1999 Fleetwood Discovery. I have had it for three years and never serviced it
  • If its adjusted and seals mechanisms are lubed with a silicone then you are good to go. Not much maintenance long as its working well.
  • Make sure you use a lube not to attract dirt and grit. I use a silicone spray twice a year.
  • You also need to spray the rubber seals around the slides to keep them from drying up and cracking.
  • Maybe I'm missing something? Bought my coach new in 2004 and I've never serviced my slide!
  • Yep! You need to spray those rail guides. Makes it easier for the motor going in and out. Same for the seals J.
