bsport's avatar
bsport
slide out
The jacks are HWH and ligths on pannel show only one yellow light. one jack came down just enough to sound alarm pressed store and it went right up,that was on way here. When I was leaveing home for the trip my DW moved in the slide and did not tell me that it moved very very slow. only when I called her this AM. Trying to fine fuses now.All else in coach work fineW Will being pluged into shore power I would think that would work was pluged 10 hours last night.
Will try to find fuse
Found trouble pump shot remove hy line retract side and pushed slide shut.
Thanks to everyone for help
bob sport
  • A fuse is like a switch...it's either on or off! If an electrical slide moves slowly, it's typically due to low voltage. Insure your battery(s) are fully charged and try again.
    Ron
