k9dad wrote:
We bring our MH home to load the night before we head out on the road. Our drive way is not level. It's inclined about 10 degrees. We have always put the slide outs out for ease of loading. Am I taking a chance in regards to slide out failure? We always put them out after leveling when we are on the road. Tried to level in our drive way but the wheels in the rear were coming off the ground. Soooo, is it mechanically safe to put them out for the limited times we are home to load?Any imput would be greatly welcome.
K9dad,
Although not vitally important, it would be nice to know what year/make/model of your coach. And, possibly what kind of leveling system you have. Most slide-out systems, have very little lateral strength. That is, if a coach is not level, front to back, then the slide tends to be influenced by gravity. It will migrate to the low slide. That means it's putting stress on parts/components/pieces that are not intended to take that much stress.
Sooner or later, there's a great possibility that eventually, something will be damaged due to the same "in-out-in-out" of the slide/mechanism. It's also quite hard on slide mechanisms to either "force out, or, force in" a slide that's not easily rolling on tracts/slides because it's LEANING against components/parts it's not supposed to. Slides that are level, roll or slide easier on components designed to hold that weight, while being level, not tilted.
So, not to drag this out but, it's your rig, you'll have to be the one to either fix it if and when it breaks due to potential slide damage from un level operations or, pay someone to fix it. Then you'll wish you would have leveled it. Your choice.
If your coach is that un level in your driveway, then, if you MUST put the slide(s) out while loading and unloading, then why not take a tad bit of time to create some drive-on leveling blocks/ramps to get your rig primarily level? Of course they would have to be substantial enough to sustain the weight of your coach. But, you'd have good stability, ALL THE TIRES AND WHEELS WILL REMAIN ON THE GROUND, your slides and slide mechanisms will love you to death and, you'll have less potential breakage. Good luck.
Scott
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
