fleetwoodflair1's avatar
Nov 02, 2023
slight vibration on acceleration
i have a 1994 Fleetwood Flair class A 22ft, I'm noticing a slight vibration when accelerating when up to speed it seems fine, could it be transmission or u joints, I only has 56000 miles but a lot of years.would appreciate some ideas.........Thanks
  • pianotuna wrote:
    Mine was on a car--a broken engine mount.
    That can be a issue that causes vibration, but mounts are unlikely to break while parked. With helper EZ to check. 1 hold brake while apply power, forward then reverse. If mount is broke, can see engine moves.
  • What chassis is your Flair on Chev or Ford>
    I would check the distributor mechanical advance.
    Plug wires could be breaking down. Cylinders 7 and 8 on Chev 7.4 can be problematic.
  • I have had issues with a truck that was parked for months, then put back in service. Just as soon as stop, hit driveline with greasegun.
    And a weak wire or plug often (Coil pack on modern engine?) is first noticed as miss under load.
  • wa8yxm's avatar
    wa8yxm
    2003silverado wrote:
    My first guess and easiest to diagnose would be U-joints or a carrier bearing on the driveshaft. Usually longer vehicles have a carrier bearing to support the driveshaft.
    silverado and I either think alike or have had the same problems.
  • Also, a plug wire starting to fail will cause a misfire while under acceleration, causing a vibration.
    Richard
  • Sounds like U joints. Also consider loose bolt on transmission or engine supports, I might find someone with a pit and have them check and tighten just to be sure.
  • My first guess and easiest to diagnose would be U-joints or a carrier bearing on the driveshaft. Usually longer vehicles have a carrier bearing to support the driveshaft.
