wanderingaimlessly wrote:
Your prior post seemed to cover this, and you only needed about 7" of rise. remember, it's wheelbase or jack locations that determine the run of your slope. the 12" your thinking of now is based, I believe, on your total unit length.
If you want a simple method to test how close you can get simply, since you appeared to need 7 inches, try getting a set of portable vehicle ramps such as these ramp
easy enough to take them back if 8" isnt enough.
Since the last post I realized that my driveway flattens a bit where the front wheels rest.
My previous 24' RV was almost level at 10.5".
I also thought my Rhino ramps wouldn't hold the the increased weight. I place them on a wooden lift ramp for an added 4".
I just now realized these plastic ramps hold 6,000 lbs.
I'm thinking of adding some more wood under the wood ramps to get me close with the Rhinos.
It would just be nice have a simpler solution.
Thanks
