- bluwtr49Explorer III had a Ready Brake before I switched to the M@G and will say it is a good braking system without a doubt....the M@G (or any air system) is frankly just superior. The main reason behind my change was the extra length of the tow bar made the fit into our barn more difficult but I am enjoying the superior performance.
As far as switching between toads, I consider that to be an insignificant benefit since I only have one toad. Besides, M@G gives a 50% trade in allowance if I ever decide to change. For those of you that have multiple toads or change every year than yes this is an important consideration. - DSDP_DonExplorerI think "willald" makes a good point about the ease of use of the Ready Brake/Ready Brute as long as you're using it on a lightweight vehicle. We tow a 6K truck and wouldn't use it in that situation. We intend to buy a smaller toad for longer trips and it would probably be a good choice for something lighter.
I also don't like adding the Ready Brake to an existing setup, I think it gets gangly and extends the toad too far back. I think if you go that route, I would buy the Ready Brute with the system built in, but that brings the cost back up. - willaldExplorer II...For a system that can be easily used on two different vehicles, that will be much, much more budget friendly than any of the systems already mentioned, look no further than the Readybrake.
Just can't beat it, IMO - Simple (one time) installation in towed vehicle of nothing more than a cable from brake pedal up to front bumper, only costs $60 more for same cable to install on a second vehicle, so you can tow either vehicle and use the Readybrake system. Simple, no-nonsense, no electronics cable operated system that simply works. Costs SIGNIFICANTLY less than the other systems mentioned, will work on almost any vehicle including hybrids (unlike M&G). And, almost all parts to it that could wear out eventually, could be found at any hardware store for less than $20 (and easily installed by the owner, no need for expensive labor). No need to wait weeks for the company to send you replacement parts like is the case for most any other brake system.
Now, it doesn't give braking quite as smooth and truly proportional as an air operated system like AF1 or M&G that works directly off of the MH's air brake system. If you have a MH equipped with full air brakes, M&G or AF1 is probably the best option (although much more expensive than something like Readybrake). However, if you have a gas coach or one that doesnt have full air brakes, then the Readybrake makes a lot more sense, IMO. - WimseyExplorerWe also have a hybrid vehicle and got tired of the set-up on our Patriot system. We had an AF1 installed this past summer and absolutely love it! It works flawlessly with our hybrid vehicle and is easy to set-up when we are ready to go. And, as has been mentioned, it can be moved to a new vehicle. I wish we had made this change earlier.
- gswcgiExplorerI have the SMI Stay & Play. Now have 46,000 miles om it and I would buy another SMI system. The MG system wouldn't fit in the engine compartment of my 2000 Nissan XTerra.
- IvylogExplorer III
- supercubExplorerI have a hybrid, and I don't believe the M&G system is available for hybrid vehicles.
- howdy35Explorer III had the M&G system installed last Wednesday on a 2014 Honda CRV and it took them all of 2 hours to install including breakaway system. This is the second car I have used that system on. Works great.
- Ray___JuneExplorer
MaverickBBD wrote:
Went from an SMI Stay-n-Play to an AF 1. What a difference, I am kicking myself for not doing that in the first place. The proportional braking is unbelievable.
The Stay-n-Play is proportional braking also. - S-n-LExplorerI have been using the SMI AirForce One for 2 years and over 20 thousand miles of towing. It has worked flawless and is out of sight and out of mind. Very easy to get ready to tow. Just connect one hose and the safety breakaway cable and your good to go.
Stuart
About Motorhome Group
38,763 PostsLatest Activity: Dec 26, 2025
