speed ohmeter is fast
kwplot34
99 Fleetwood tioga ford E350, V10. Is it normal for the speed/o to read fast on motor homes. Ours compared to the GPS reads 5 MPH fast. At 70 MPH the GPS says 65MPH. The GPS is accurate, have had it for several years and compared it with our other 4 vehicles and they read the same MPH.
16 REPLIES 16
kwplot34
CaptainCal wrote:
99 Ford's use an electric speedometer. They can be reset by you to read accurate for tire size changes. Type in 99 e350 speedometer on {YOU TUBE}. It will give you instructions on how to. Get the value that your speedo is presently set at and start from there.
Thanks for the information
CaptainCal
kwplot34
Matt_Colie wrote:
Nobody's speedo is right on, you have to look. Is the error constant or linear. Meaning is the error always 5 or is it half of what you see at 70 when you are at 35??
The constant error can be fix as above, more the pointer on the shaft. If it is linear, then call a Ford dealer. Manufactures often have different speedo pickup gears for this. When they build a transmission they don't know what the final drive will be and the driveline people don't know what tires will be on the assembled vehicle.
Matt
The faster you go, the greater the difference,
Matt_Colie
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
ronfisherman
Moderator
Moderator
On my Chevy Kodiak chassis the speedometer was reading off from GPS. The ScanGaugeII read correct for MPH to GPS. Removed gauge cluster from dash. Removed needle from step motor and positioned to more correct location. Speedometer now reads within 1 MPH of GPS.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
kwplot34
Thanks for all of the reply's. The tires are the correct size, I might try a shop and have them check the calibration. It is not huge issue, just kind of annoying.
tatest
Federal Motor Vehicle Safety Standards allow some small error, and there will always be a chance of error with variation in tire diameter from brand to brand (even in the same nominal size) and changes with wear. The standards do not allow the speedometer to read slow enough for you to notice, so it will normally be calibrated to read slightly fast at some speeds.
My last truck read 3-5 mph fast at slow speeds, caught up with the GPS at about 65-70. My current truck (E-350) reads about 3 mph fast a slow speeds, 1-2 mph fast at 70 mph.
Tom Test
Itasca Spirit 29B
crasster
Cobra21 wrote:
If the tires are smaller than factory spec. it will read fast. Check if they
are the correct size?
X2 This absolutely can make a difference.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
tpi
My E450 has always read about 2 MPH faster than GPS indicates. Quite typical.
dicknellen
My e-350 Winnie is 1 to 2 miles slower than my Garmin GPS. Have not done a MM check. Tires are the correct size. Dick
TucsonJim
Most cities have shops that will calibrate your speedometer. Just do a search for:
"Speedometer Calibration". Many options should pop up. I just did a search for my city of Tucson and had 1/2 dozen shops show up.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
WyoTraveler
I think 3 to 5 is not uncommon.My MH is slightly fast. Not enough to measure. My PU is about 3 mph fast. Never saw one slower.
enblethen
Tires are not of correct size for speedo setting in computer. many tire shops have OBD unit to change.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
valhalla360
Nomad III
Nomad III
I don't think it's a MH issue. We rent cars several times a year for work and 3-5mph faster than actual speed is pretty common (based on comparison to a couple of GPS that match each other). Sometimes, they match dead on.
Never see one show a lower speed...of course that may be a liability thing. The manufacturer doesn't want the blame if the speedo says 55mph and you get a ticket for doing 60mph.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
