gbopp
Mar 22, 2017Explorer
Just my opinion but, I would change the generator oil. It's cheap insurance.
I don't know if a Ford dealer will work on a generator? It's an easy DIY project.
Did you put a load on the generator when it operated for an hour every month?
Clean the battery terminals. A little corrosion that you can't see can cause problems.
Also, I assume you can check tire pressure yourself? It should not just be checked at the beginning of the season. If you don't know how, learn.
If you can't, at least get a Tire Pressure Monitoring System.
