โAug-03-2019 08:40 AM
โAug-09-2019 01:21 PM
โAug-09-2019 12:18 PM
Desert Captain wrote:
"With most Ford based specs sheets I've looked at, to carry the full GVWR "legally", all 4 corners have to be loaded to exactly the capacity of the tires. "
I sincerely doubt that statement. I run my E-350, GVWR of 11,500# at or at least very near that max number on almost every trip. My tires are nowhere near their max load capacity which would necessitate running all 6 at 80 psi. If you do you will have the worst handling Class C ever.
Heavily loaded I run the fronts at 65 and the rears at 70-75 and that still leaves a serious fudge factor before getting anywhere near their max capacity. My FAWR is 3,800 and the Michelins are rated for 5,340# {2,670 each}. The RAWR is 7,800 and again the Michelins are rated for 10,680.
Running these pressure my rig drives and rides great. Big rigs do not push me around and wind up to 35 mph is still two finger steering. I'm sure the heavy duty Bilstein's help a lot but it would be hard for me to imagine a better handling motorbhome than mine.... this after 50,000+ miles over the last 6 years.
:C
โAug-09-2019 11:13 AM
โAug-08-2019 09:41 PM
โAug-03-2019 06:33 PM
โAug-03-2019 06:10 PM
nitecapt wrote:
Just for clarity, aren't the passenger weights considered part of the OCCC? If so and you have 4, 150 lb passengers on a 1000lb OCCC, you will have only capacity for 400lbs.
And what do you like with the Ford Chassis in a 24' size MoHo
โAug-03-2019 04:39 PM
nitecapt wrote:E350 advantages
โAug-03-2019 04:17 PM
โAug-03-2019 03:48 PM
โAug-03-2019 03:44 PM
โAug-03-2019 03:38 PM
nitecapt wrote:
his is all good info......I think the Galleria Coachman has a large capacity but they are SOOO expensive
โAug-03-2019 03:37 PM
โAug-03-2019 03:33 PM
โAug-03-2019 03:12 PM
midnightsadie wrote:
might look at these leisurevans.com we have the freedom serenity 11 has been great ,ours has the MB engine 5cyc and nobody beleaves we hit 20mpg now and then pulls my boat and gets 17teen. its now getting up in age a 2007 but we,ll keep it.
