- Horizon170ExplorerMany thanks everyone. Inside and outside works for me depending on the situation.
Marvin - firefighter33ExplorerHave used both depending on the situation. For longer stays I prefer the outside covers, but for short stays or ease of use I use the indoor covers. Using both provides more insulation on hot days. Hope this helps.
- JohninSDExplorerI use a Fanchers outside cover when it's hot, along with a piece of Reflectix between the windshield and the cover. When it's cool or raining and I just want privacy I use the inside pleated shades that came with my Navion. With the Fanchers cover it is important to be careful installing and removing it to avoid scratching the paint (it is held in place with magnets in the corners). Don't drag the corners across the paint! If there is any dirt or especially sand on the cover it will scratch.
- wendylyExplorerWe found our inside covers at https://sprinterstore.com
We've used them for two years without any issues. - Deb_and_Ed_MExplorer IIWe had both inside and outside for our E-450, used whichever one fit the situation. If rain was forecast, we used the interior set so we didn't have to store a wet outer cover. If it was hot, we used the white outer cover to reflect heat. If it was really cold, we used both for extra insulation.
- IAMICHABODExplorer III had the inside ones and hated them,cumbersome to to put up and store. If you want to see out you had to take them down,then put them back up at night to get privacy.
I chose the outside one with the roll down shades, With roll-down window panels, you have the option of total privacy as well as the ability to take in the views.
Also roll down the door windows to get more air in the cab with a screen over them.
Like This - I had an outside windshield cover for my first RV. Hated it! Doing/undoing got me all dirty and left me with the wet or dirty cover to store inside during the day. Plus, I worried about dirt on the cover scratching the RV. The only advantage I can think of is that the cover possibly protected the wiper blades from sun damage.
I have been happy for many years now with interior covers which I made from Reflectix. Privacy plus insulation. Always clean. Roll up or lie flat for storage. - toedtoesExplorer IIII ow lots of folks who use the outside type. Personally, one of the things I like about a class C is the ability to walk from the house to the cab and drive away without having to go outside (I rarely go places with hookups). So, I prefer inside shades.
- Johno02ExplorerGo to Walmart, and buy Eclipse Rom darkening shades n full size. Use the material to custom make shades that fit. Slide strips and rolling hangers are available at RV supply places. Here is a picture with full sum on the outside, and also the dash cover we made.
38,705 PostsLatest Activity: Jan 24, 2025
